pre-defined macro
yang hong
I would like to use #define macro in my program to hold application, firmware version and firmware building time.
I know i can put these definition into my program directly, and make modification before I compile my program.
Could I use GNU C to pass these macro when I compile my program? I know I can set some macro on path and symbols in properties for project. but I am not sure I can do it for the user-defined macro?
Thank you for any help!
turboscrew
Senior III
I haven't done that, but I'd look into -D switch of the compiler...
Like -DVERSION=2
