2017-03-29 12:21 PM
I recently upgraded to a new version, 4.20, and its has been giving us a lot of issues. Unfortunately I deleted 4.18 installer, Is it possible to provide a download link to an older version of the cube?
I am working on a commercial product and things like these are a big time sink for us.
2019-01-23 07:40 AM
Some older versions of STM32CubeMX are now available for download on ST web site.
Kind Regards,
Imen
2017-03-29 01:46 PM
Adding up here as ST has stolen "Best Post" that showed the deep post first.
The new forum destroyed the link titles, so going to fix here, and see if the 3 link limit has been removed, click Show More to expand the post
v4.2.0 https://drive.google.com/open?id=0B7OY5pub_GfIbHZVV0RtN2hZUm8
v4.3.1 https://drive.google.com/file/d/1uqDpQ1-np80z76YAxUTbX2fw2D3hktdL/view?usp=sharing
v4.4 https://drive.google.com/open?id=19ZunVFHvSQMZ6pvFlSabv8i1r8-HeQl9
v4.9.0 https://drive.google.com/open?id=0B7OY5pub_GfIckg0RU5CdGlqTFU
v4.10.0 https://drive.google.com/open?id=/0B7OY5pub_GfIRC1oMEYtTTVfaTA
v4.14.0 https://drive.google.com/open?id=1TRMT3gLebX0ymNjnXJwzrWjup-LJGIta
v4.15.0 https://drive.google.com/open?id=1NklqV8tGYvfTvoQZ9tM4T-yxfeyqFcyX
v4.15.1 https://drive.google.com/open?id=1F6meIlJRrnMPblBumeVyF0k_lRVvMQpQ
v4.16.0 https://drive.google.com/open?id=0B7OY5pub_GfINEVlT01sYzAxRU0
v4.17.0 https://drive.google.com/open?id=0B7OY5pub_GfId0NMdzVSeEhZT1E
v4.18.0 https://drive.google.com/open?id=0B7OY5pub_GfILUVZTXdKUkV6eU0
v4.19.0 https://drive.google.com/open?id=1KTdiPxQSgnhLnVZe7SeyutURmUpZaraq
v4.20.0 https://drive.google.com/open?id=0B7OY5pub_GfIdUxPaDl0ZFV3Q1k
v4.21.0 https://drive.google.com/open?id=1BCnG5z03V8mKEQmL76cecNUoI745a_fZ
v4.22.0 https://drive.google.com/open?id=1-9l-vPb35xm1kvOXxbOQrDKzTtPMnx22
v4.23.0 https://drive.google.com/open?id=0B7OY5pub_GfIbUYzWGZaU2dsRUE
v4.24.0 https://drive.google.com/open?id=1nclMp0ESduH4Y2B9cmKLpI3FAo9GUzgG
v4.25.0 https://drive.google.com/open?id=19ztTJrZvwQy-Hb4i3FwAk5yoR10nY63i
v4.25.1 https://drive.google.com/open?id=1ZuISNv5YHT7ZcnJeXOgYI3iZqE2wKjQm
v4.26.0 https://drive.google.com/open?id=1D702wAecmeYyZoBLzz25dPIBNwsFzvTG
v4.26.1 https://drive.google.com/open?id=1Jq3U0bTwpZ3hsOmOv6mkHlIjMuFID_qT
v4.27.0 https://drive.google.com/open?id=16uTm4TBdgU05XQyJPUvzOhC6aJWpqloa
v5.0.0 https://drive.google.com/open?id=1bA_wRq-p-m7KGlAy-KofRkRRUJ7godKj
v5.0.1 https://drive.google.com/open?id=1rQOLvuHWcVpOoWcw3qPzqF6WachrjiJi
v5.2.0 https://drive.google.com/file/d/1sioE1mVu-DmmE2caYkmkra3WkCBz1K9b/view?usp=sharing
v5.2.1 https://drive.google.com/file/d/18YltzUJq-lqrH6KAGshB_rk0IiyQUTA5/view?usp=sharing
v5.3.0 https://drive.google.com/file/d/1Cfqrztk_joB7svEQbBXDPSkAHnVKYzfX/view?usp=sharing
v5.4.0 https://drive.google.com/file/d/1iSNDpi7Yn7BlFXxXHe4aaG6OY49I3El3/view?usp=sharing
v5.5.0 https://drive.google.com/file/d/1cLdrc8nR-9FCqQh5OdZt8VEi6eFGxY0N/view?usp=sharing
v5.6.0 https://drive.google.com/file/d/1Qci1JT5SkUPqo9itR41_K089UK6Uxa19/view?usp=sharing
If this post is helpful, please help maintain the mirror and my work here by contributing via PayPal or with Amazon Gift Cards - sourcer32@gmail.com
2017-03-30 01:13 AM
Hi
Panuganti.Jnana.002
,Could you pleasedescribe clearly the issue that you faced with CubeMx 4.20?
Imen
2017-03-30 08:45 AM
Hi
Panuganti.Jnana.002
,Turvey.Clive.002
,Iraised your feedback internallyas this will help us to improve our service wherever possible,
in the hope to provide an answersoon.
Imen
2017-03-30 09:28 AM
Please find here the 4.18 version:
https://drive.google.com/open?id=0B3TGwFlypwI6aEFuRVVmUTB3Nkk
Please note that 4.20.1 will be released soon to fix issues. Sorry for the inconvenience.
2017-03-30 09:55 AM
Given the noise on the forum I'd say a whole slew of regression issues, but the question isn't one to be solved by fixing today's problems, but one of providing an archive of prior releases that is easy to find and navigate.
The releases should have comprehensive change logs, and be thoroughly regression tested, diffing the builds and doing this testing isn't the customer's job, and this one is complaining that it is sucking up his resources, he wants to focus on getting a working product out of the door.
2017-03-30 11:48 AM
Thanks for the Links Clive and ST! Issues I faced with 4.20 are already mentioned in the forum.
As Clive mentioned, it is necessary to have a way to download older versions of software.
I have been using ST micro controllers from 4 years, and had used standard peripheral libraries.
I truly appreciate the effort ST has put into cube and HAL libraries to make developers life easy.
Bugs will always be there in software, and newer versions may fix old issues but sometimes create more issues, and given the complexity of what cube does I understand it is hard to test for all possible cases.
So, as a good practice it will be great if ST can have archives for cube and any other software tools. Some of us are using these in Automotive and Medical industries and having access to older software versions of third party software makes a big difference.
Nevertheless, I will also make sure to backup any tools I download into version control system!
2017-04-01 11:24 AM
Yes, please provide archives for each revision and also for the FW packages for each controller series.
2017-04-01 11:33 AM
Given the size and availability issues the use of BitTorrent has been suggested previously.
2017-04-02 11:37 AM
Hi
Rudolf.Markus
,The
older versions of the firmware packages are available and it ispossible to
download old version from CubeMx tool by c
licking on Help->Install New Libraries
Imen
