Please confirm my opinion about external interrupts
baranovus
Posted on August 20, 2010 at 22:02
4 REPLIES 4
Posted on May 17, 2011 at 14:03
What does the Datasheet say?
(I've certainly used PC1 for an external interrupt)
dthedens2
you should look at RM0008.pdf
Figure 21
read section 9
baranovus
Well, thanks to everybody.
The guy was partly right. I really cannot use PA0 and PC0 together. Everything seemed so clear...
Nickname12657_O
You can have ''PA0'', ''PA1'', ''PC2'', ''PC3'', ''PA4'', ''PA5''  all enabled at a time, but not  ''PC0'', ''PC1''  and inputs 0 and 1 are already assigned to  Port A, but you can configure them later if all them are not used in same time.
Cheers,
STOne-32.
