2012-01-23 7:04 AM
I want to play wav files from an SDCard with my STM32F2xx. I used SDIO example and I added FatFs support on it and it's OK. Next, I tried to use STM audio example to play audio from memory, and it's work (first I had a problem with I2C and I fixed it). Those two examples work fine but, when I want to add SD support on audio example, SD don't work anymore, and when I add audio on SD example, audio don't work ... Maybe someone already tried this on a STM32F2xx. Thanks.2012-03-08 5:37 AM
Hi Damien
Were you able to achieve playout of wave through SD Card. I am trying the same on an STM32F4XX but I am facing problems. My playout is start-stop and not continuous. Let me know if you were successful.2012-08-21 2:38 AM
Hi damien,
have you solved your SDIO+I2C problem?Why this question?I've problems reading the SDCard, while using a touchscreen I/O interface, that uses I2C. Best regards,Holger
