Pins configuration after reset
ybitton
Posted on May 31, 2012 at 16:17
What is the GPIO pins configuration after reset?
Where can i find it?
Thanks - Udi.
#gpio
frankmeyer9
Posted on May 31, 2012 at 19:54
For STM32 part, usually in the Datasheet.
There is a section called ''Pinouts and pin description'', which lists all possible functions of the pins and their characteristics.
In this section, you find a ''pin definitions'' table, including one column ''function after reset''.
In contrast, the reset values of there peripherals are found in the Reference Manual (that document with 1000+ pages).
