Simulation Problem in keil 4.2V
k_hraj
Posted on October 15, 2011 at 10:03
I could not simulate my code written for STM32F205ZE using keil 4.2V.Following is error code it is showing, when I start debug session.
*** error 65: access violation at 0x0000000C : no 'read' permission
If I try to run it is showing:
*** error 65: access violation at 0x00000000 : no 'execute/read' permission
Please give me suggestions to solve this problem.
Posted on October 15, 2011 at 17:53
http://www.keil.com/support/docs/814.htm
Try reviewing documentation
Try Keil technical support
Try using the most current release (v4.22 last I checked)
rales
Posted on May 31, 2012 at 16:51
I have the same problem, and cost about 6 hours screwing around ''trying'' stuff, still doesn't work...
Never had a problem with NXP,  now I will be ''trying'' a different line of processors!
Posted on May 31, 2012 at 17:19
But ST isn't responsible for the failings of KEIL software.
KEIL does not represent that the part is simulated.
http://www.keil.com/dd/chip/5110.htm
ST has eval boards in the $10-20 range that permit testing on a physical part. Simulators classically fail to represent the nuances of the silicon implementation accurately.
