On STM32H7, can DMA access generate an ECC error ?
PBard.2
I am currently working with stm32H743 processor.
I wanted to know if DMA access can trigger an ECC error or only the core can generate these errors.
For example if there is a ram data protected by ECC with a double bit error, would a DMA access to this corrupted data generate a bus fault error ?
waclawek.jan
I see no reason why not.
