2018-02-19 10:08 AM
I would like to use the mentioned nucleo board and compine it with an x-nucleo-ips02 board. When comparing the pinouts i did not find corresponding pins on the connectors. Is the necleo-144-board incompatible the the connectors of the x-nucleo shields?
Kind regards, Kurt
2018-02-19 10:43 AM
All nucleo boards accept Arduino UNO R3 shields, which is the connector format on you nuc shield.
