2024-06-16 07:29 AM
I have connected the nucleo f756zg board with the qorvo dwm3000. I found the inc and src files for the dwm3000 but the drivers for the dwm3000 are available for the m33 and m4 families.
Is it someone who used an M7-Cortex mcu and have the driver for the dwm3000? Or, is there any other way to go?
Thank you in advance,
Dim
2024-06-16 08:42 AM
If you've got the source files, port it. Work with the vendor their FAE's or consultants.
CM4 code should run on a CM7
Related to these?
https://community.st.com/t5/stm32-mcus-embedded-software/dw3300q-stm32-sdk/td-p/676724
2024-06-16 12:31 PM
Here you can find help with adaptation or development of the driver.
2024-12-16 03:03 AM
Same question, but for Nucleo-446:
https://community.st.com/t5/stm32-mcus-boards-and-hardware/nucleo-f446-with-qorvo-dwm3000/m-p/753838
