Moving variable into ITCM-RAM STM32H7 Series
PGuru.1
I want to move some of application variables to ITC-RAM. What are the changes to be done in linker and startup script?. Thanks in advance.
Nikita91
Lead II
I use these files. A start point for your own files
Guru
Note that ITCM is meant for instructions (code), not data. The DTCM is meant for data. Not sure if there are restrictions/drawbacks against storing data in ITCM.
