Mising startup file
jasonp4113
Posted on September 23, 2014 at 00:15
Hi All,
I have done a search to no avail on this:
Using Keil tools and Cube 4.3.1 (STM32F407), generating the project results in missing the startup file - but only at random.
The folder ''Application/MDK-ARM'' does not get generated or included in the project.
Re-creating the project again with cube will then put it back in - but this is annoying.
Posted on September 23, 2014 at 01:04
Cube issues generally getting handled in the [DEAD LINK /public/STe2ecommunities/mcu/Lists/STM32Java/AllItems.aspx]other forum page
jasonp4113
Posted on September 23, 2014 at 01:47
Whoops! you are correct.
Is there a way to delete posts in here?
All I can see is to edit it to <no text>
