Minor error on reference manual RM 0410
Dimitris Paraskevopoulos
Posted on March 22, 2018 at 17:49
Hi in the reference manual for for STM32F76xxx and STM32F77xxx  which can be found here:
http://www.st.com/content/ccc/resource/technical/document/reference_manual/group0/96/8b/0d/ec/16/22/43/71/DM00224583/files/DM00224583.pdf/jcr:content/translations/en.DM00224583.pdf
There is a small typo on Section 2.2.2 Figure 2 that shows the Memory Map.
The error is in the Reserved Area above Flash memory on ITCM interface which should start from the end of Flash and should be 0x00400000 - 0x07FFFFFF instead of
0x0030000 -
0x0
7FFFFFF
 which conflicts with the area for the ITCM Flash I/F
#reference-manual-error
Nesrine M_O
Lead II
Posted on March 23, 2018 at 11:17
Hi
Paraskevopoulos.Pana
You are right. Thank you for bringing this issue to our attention.It is noted and will be fixed in coming release of the document.
-Nesrine-
Nesrine M_O
Lead II
Hi
-Nesrine-
