yang zhichao
STM32F103R8T6 - power consumption 5x higher than product parameters
  • March 23, 2018
  • 5 replies
  • 976 views
Posted on March 23, 2018 at 09:54
The difference between the product parameters and the sample power consumption of batch production is too great. It is found that the power consumption of the single chip is five times. How should I judge the STM32F103R8T6 I bought is real or fack?
    yang zhichao
    Posted on March 23, 2018 at 09:56
    my email is
    mailto:myyzc@163.com
    Andrew Neil
    Posted on March 23, 2018 at 11:09
    http://www.catb.org/~esr/faqs/smart-questions.html ♯ noprivate
    AvaTar
    Senior III
    March 23, 2018
    Posted on March 23, 2018 at 10:30
    You should be a bit more specific.
    A custom board you designed ?
    Perhaps you damaged it, or operate it out of specs ?
    What are the actual and expected power consumptions (mA at which Vcc and which clock frequency) ?
    Andrew Neil
    Posted on March 23, 2018 at 11:13
    What 'product parameters' are you referring to?
    Power consumption is very much dependent on the application - so are you sure that your application is running under exactly the same conditions?
    Are you sure you are measuring just the microcontroller current - not also other parts of your system?
    If this is a custom PCB, do you get similar results on an ST board (Nucleo, Discovery, whatever) ?
    Nesrine M_O
    Posted on March 23, 2018 at 11:34
    Hi
    myyzc
    Could you please provide more explanation on your case, so that it will be easier to understand the issue?
    1- Which power mode did you measured (voltage,frequency ,test parameters)?
    2-What do you mean by '
    product parameters '?
    3-Please refer to the product
    http://www.st.com/content/ccc/resource/technical/document/datasheet/33/d4/6f/1d/df/0b/4c/6d/CD001615pdf/files/CD001615pdf/jcr:content/translations/en.CD001615pdf
    and tel us about the exact power mode that you are looked to?
    4-Are you using a custom board?
    -Nesrine-
