2015-08-20 05:40 AM
I am using NucleoL152RE with X-NUCLEO-IKS01A1 .I loaded x-cube-mems1 Datalog sample code.but that pc suite is not working.
2015-08-20 06:29 AM
Hi a_b.krishnapriya,
Ensure that the necessary drivers, are installed and the expansion board along with STM32 Nucleo board is connected to the PC.I suggest you to follow the setup guide described by this .-Syrine-2015-08-20 06:35 AM
This
also can be helpful.-Syrine-2016-07-15 05:01 AM
Hey a_b.krishnapriya, i am facing the same problem, did you get it sorted out???
Can you please share the solution here too..
