Mems sensors_datalog is not working
krishnapriya
Posted on August 20, 2015 at 14:40
I am using NucleoL152RE with X-NUCLEO-IKS01A1 .I loaded x-cube-mems1 Datalog sample code.but that pc suite is not working.0690X00000605IYQAY.png
#x-nucleo-iks01a1
3 REPLIES 3
Nesrine M_O
Lead II
Posted on August 20, 2015 at 15:29
Hi a_b.krishnapriya,
Ensure that the necessary drivers, are installed and the expansion board along with STM32 Nucleo board is connected to the PC.
I suggest you to follow the setup guide described by this
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/user_manual/DM00157069.pdf?s_searchtype=keyword
-Syrine-
Nesrine M_O
Lead II
jaiagg
Posted on July 15, 2016 at 14:01
Hey a_b.krishnapriya, i am facing the same problem, did you get it sorted out???
Can you please share the solution here too..
