M95512 and STM32F103 SPI3 (no have Read Data)
‎2018-09-10 5:35 AM
Dear all
Hello?
Now I use STM32F103 SPI3 and M95512(SPI EEPROM).
void SPI3_Config(void){
SPI_InitTypeDef SPI_InitStructure;
SPI_Cmd(SPI3, DISABLE);
SPI_I2S_DeInit(SPI3);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI3, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO, ENABLE);
GPIO_PinRemapConfig(GPIO_Remap_SPI3, ENABLE);
// SCK MOSI
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_5;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOB, &GPIO_InitStructure);
// MISO
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
// CS
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
// SPI configuration -------------------------------------------------------
EEPROM_CS_HIGH();
SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;
SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge;
SPI_InitStructure.SPI_NSS = SPI_NSS_Soft;
SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
SPI_InitStructure.SPI_CRCPolynomial = 7;
SPI_Init(SPI3, &SPI_InitStructure);
SPI_Cmd(SPI3, ENABLE);
and
uint8_t SPI_SendByte(uint8_t Data){
while ((SPI3 -> SR & SPI_I2S_FLAG_TXE) == RESET);
SPI_I2S_SendData(SPI3, Data);
while ((SPI3 -> SR & SPI_I2S_FLAG_RXNE) == RESET);
return SPI_I2S_ReceiveData(SPI3);
void SPI_WriteByte(unsigned char Data){
SPI3 -> DR = Data;
Data = SPI3 -> DR;
unsigned int M95512_RDSR(void){//0x05 Read Status Register
unsigned char data_H, data_L;
unsigned int data;
EEPROM_CS_LOW();
SPI_SendByte(RDSR);
data_H = SPI_SendByte(DUMMY); //SPI_ReadByte();
data_L = SPI_SendByte(DUMMY); //SPI_ReadByte();
EEPROM_CS_HIGH();
return data = (data_H << 1) + (data_L << 7);
When I read RDSR data is 0x0104
I don't know mean
When I see data sheet RDSR is only 8 bit
But read 2 byte.
now STM32F103 SPI3 work CS, SCK, MOSI clock.
When I read another adress. than no have receive data.
How can I check.
Please help me. Thank you~
and sorry My english.
‎2018-09-10 5:59 AM
Hi @Kim Sang Hyouk​
First of all, you just mention your STM32F103 family and you didn't clarify your exact MCU.
you should config your MISO pin as 'Alternative Function and Push Pull' to be able to read from SPI.
‎2018-09-10 7:49 AM
Input Floating is a legitimate setting for MISO on the F1 series parts
You'll basically have to scope the pin, or use logic/protocol analyzer, and confirm the patterns seen on the pin to those reported by the STM32. You might have to review polarity/phase of clock.
Sorry not using either of these parts.
With PB3 you might want to make sure SWV functionality is not mapped on the pin, so check the SWD/JTAG remapping options in manual.
‎2018-09-10 9:45 PM
// MISO
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; // GPIO_Mode_IN_FLOATING;
MISO Pin GPIO_Mode_AF_PP or GPIO_Mode_IN_FLOATING
both Work is Good.
This is RDSR Requeset 0x05;
RDSR Read Data 0x02 0x02
‎2018-09-10 9:50 PM
​now Just can Read RDSR
while(1){
M95512_WRDI(); //Write Disable
Error = M95512_RDSR();
delay_us(1);
M95512_WREN(); //Write Enable
delay_us(10);
When I test .... Cand Read 0x00 0x00 and 0x02 0x02
But Can't Read
void Read_Door_Sens(void){
unsigned char data;
ADDRESS = 0x0000;
EEPROM_CS_LOW();
SPI_SendByte(READ); //0x03
SPI_SendByte((ADDRESS & 0xFF00) >> 8);
SPI_SendByte(ADDRESS & 0xFF);
data = SPI_SendByte(DUMMY);
EEPROM_CS_HIGH();
Door_Sens_Use = data;
void Write_Door_Sens(unsigned char data){
ADDRESS = 0x0000;
// M95512_WREN();
EEPROM_CS_LOW();
SPI_SendByte(WRITE);//0x02
SPI_SendByte(data);
EEPROM_CS_HIGH();
MOSI Signal Can work.
But MISO Signal Can't work.
