2017-12-01 8:08 AM
Hello
For my project i need larger fully compatible with HALL fonts. I have 24 size font, but i need at least 5 times larger. Or any larger will doAny one know where to find it ?Thanks#fonts #hall2017-12-01 8:49 AM
Probably want to look at vector fonts, large bit-map fonts will eat a lot of space.
2017-12-01 10:33 AM
Well, i did similar think for numbers. But that is only 10 numbers. i need all letters, all numbers, it can be tedious
2017-12-01 10:38 AM
I swear there was a Segger utility, saw at a seminar of F4 or F7, which would cherry pick a Windows Font, and build a data table. ie you could select a subset of the alphabet, case, numerics, etc.
2017-12-01 10:44 AM
Yikes, $2800
https://shop-us.segger.com/emWin_Font_Converter_p/3.04.00.htm
Pulling a copy of STemWin to see if it is in there, otherwise going to dig through Seminar Flash Drives...
