2014-06-21 5:18 AM
Hi.
I am a beginner in microcontroller programming and new on this forum also.I have a development board EM-STM3210E with STM32F103ZET microcontroller and i try to make a simple project (turn ON a led) using Keil uVision5.Can somebody told me how to proceed.I am stuck in this point (see attach file).What option i should choose.Thank you. #keil-uvision2014-06-23 3:37 AM
http://www.st.com/web/catalog/tools/FM147/CL1794/SC961/SS1743/LN1734/PF257890
which contains a template for various toolchains. So you can copy the example you need in the template directory & the use your preferable toolchain to compile it. -Mayla-To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
