paul0208
IWDG is not working
  • October 8, 2019
  • 4 replies
  • 936 views
In stm32f051, iwdg is not working, I think.
After enable iwdg, encounter the while(1); loop , reset is not issued.
NRST pin is connected to RC reset circuit.
BR
Paul
It works. You either didn't enable it or have incorrect settings. But since you posted no code and no info apart from that you enabled it, we can only guess at what the problem is.
paul0208
paul0208Author
My iwdg enable code is as follow:​
void
WatchDog_Config (void)
 /* Enable write access to IWDG_PR and IWDG_RLR registers */
 IWDG_WriteAccessCmd(IWDG_WriteAccess_Enable);
 /* IWDG counter clock */
 IWDG_SetPrescaler(IWDG_Prescaler_32);
 IWDG_SetReload(96000000L/32);
 /* Reload IWDG counter */
 IWDG_ReloadCounter();
 /* Enable IWDG (the LSI oscillator will be enabled by hardware) */
 IWDG_Enable();
DBG ("IWDG Started\n");
BR
Paul
The RLR register is 12 bits.
And even if the value wasn't out of range, your IWDG would take 40 hours to trigger a reset.
96000000/32*32/40kHz = 40 hours
