Is there any template or example program for implementing OTA? I have 2MB SPI EEPROM, SIM808 for GPRS communication and STM32F070 on board.
Ahmed.Waqar
Posted on February 24, 2018 at 13:03
I am using CoIDE and have little understanding about how to do it, such as
  • Receive binary file to the board form GPRS module
  • Save it in external flash memory then use IAP to flash the new firmware
  • Then finally use DFU mode for changing the start address of the MCU
But except receiving the binary file and storing it in EEPROM, I have no idea about how to proceed further. Please provide assistance.
#clive #clive1 #clive-one #andrew-neil
12 REPLIES 12
Posted on April 20, 2018 at 14:27
The conversion has been forked to this thread
https://community.st.com/0D50X00009XkfgXSAR
This seems to describe more RAM than is physically available in the F103C8, ie 20KB 0x20000000..0x20004FFF
Ahmed.Waqar
Posted on April 21, 2018 at 10:37
Thanks Sir
Turvey.Clive.002
. Now I am using STM32F103RE that has 64k ram. But when I configure its clock, debugger gets struct in while loop at
if (HAL_RCC_OscConfig(&oscinitstruct)!= HAL_OK)
/* Initialization Error */
while(1);
Please check the following modification for 8 MHz HSE. Am I doing it wrong?
I am using following IAP example
.\AN4657-STM32Cube_IAP_using_UART\Projects\STM3210C_EVAL\IAP_Main\EWARM\STM3210C_EVAL\
Posted on April 21, 2018 at 10:46
Even it is getting struct with following configuration as well
