Is there a way to overcome "pausing" during DMA Circular transfer?
ambrose
Hello I am using the STM32F334 for Lighting and I have had to use the DMA to transfer duty cycle data to the PWM duty register. The DMA is set up in circular mode and there is no interrupt. The priority it set to High. But i notice this pauses between the packets. I would have expected it to have no pauses. Please how can I get rid of this? Please see the image of actual light intensity. Hope to hear from you. thanks
11 REPLIES 11
ambrose
@Uwe Bonnes​ You were right; It was off by 64. thanks
waclawek.jan
So if it's solved, please select Uwe's post as Best, so that the thread is marked as solved.
Thanks,
