Is it possible to set the output of stm32f407 to pinpoint the speed of the pins to kHz. I would appreciate if you can help ..
bnymntrz
The TIM peripherals can drive pins into the 10's of MHz
What you don't want to be doing is interrupting in the 100's of KHz
Do we interfere with the clock signal with TIM peripherals. That's good
