Is DMA Double Buffer Mode only Peripheral to Memory?
‎2017-07-28 5:40 AM
It appears from the (rather lacking) documentation that the DMA Double Buffer Mode is only a Peripheral to Memory transaction. Is this correct? Or can I use double buffering from memory to peripheral?
‎2017-07-29 1:13 AM
Please specify, which part are you using.
AFAIK, the single-port DMA (F1/F0/L1/L4/L0) does not feature double-buffer mode.
I am trying to find a RM with the 'F2/'F4/'F7-style double/triple-port DMA, where textual search for ''double'' would not stumble upon several mentions of both direction being available, including the following table:
PS. Amel, RM0090 of 'F0xx, RM0360 of 'F030 and possibly others contain a mention of ''double buffer mode'' in the ADC chapter, which probably ought to be removed.
‎2017-07-28 6:07 AM
On what part?
I'd assume the implementation will be highly symmetrical. The mechanics are there to ping-pong between two buffers whether the transfer is to or from is a separate and independent step in the sequence.
Not single memory to multiple peripherals.
‎2017-07-28 10:01 AM
Hi
Hooper.Mike
‌,In
we say 'A double-buffer stream works as a regular (single-buffer) stream, with the difference that it has two memory pointers. 'So both directions can be used.
-Amel
‎2017-07-29 1:13 AM
‎2017-07-29 6:16 PM
Ok
Waclawek.Jan
‌, I'll take care to check this.-Amel
‎2017-07-31 6:10 AM
Thanks all. I did eventually find the above mentioned table in the RM and will be giving it a try this week.
