Is Code Sourcery worth the effort ?
jlchoobs
Posted on May 28, 2012 at 18:28
I have been using the Atollic (Lite) for my development.
My Atollic Projects work great (doing USB & MMC work).
But I have run out of space with the 32K limit.
So I moved over recently to the Code Sourcery - or tried.
I can compile a simple: main(){while(1){}} program , etc.
But when I try to move and compile my Atollic Projects,
they do not compile.
Simply:
  make -k all
 - with no file outputs, warnings, errors, etc.
I have been using Eclipse WinArm for Atmel for years.
I followed most specs that I could find - on installing Code Sourcery on Eclipse,
 - but with no result.
Is Code Sourcery supposed to work like a Black Box ?
Is there some Verbose parameter needed or something ?
- Any Advice ?
- Does anybody actually promote Code Sourcery ?
14 REPLIES 14
frankmeyer9
Posted on June 07, 2012 at 14:10
As a matter of fact, even advanced technological capabilities are not necessarily accompanied by corresponding interhuman communication skills.
I see this discussion steering more into the irrational direction.
So I remember that golden forum rule and not going to feed you anymore...
jlchoobs
Posted on June 07, 2012 at 16:01
.. Your FINALLY learning fm ..
So, can you keep off my other Topics also - until you learn to Respect this Golden Rule - and stop dumping Your Wasteful Negativity on all my posts ?
I think others also reading this - don't want to hear you either - you provide nothing Useful - only rhetoric ...
By the way - what don't You Understand about the Words : 'Go Away' - ?
- You still don't get the idea ...
frankmeyer9
Posted on June 08, 2012 at 16:42
That Golden rule is: ''don't feed the troll''.
Andrew Neil
Posted on June 09, 2012 at 15:35
''This is a Public Forum''
Indeed it is - so you don't get to choose who may contribute!
Ever heard the expression, ''beggars can't be choosers''...?
''if you can't provide Free Advice - then Go Away !''
I am happy to refund double the price you paid for my advice...
Andrew Neil
Posted on June 09, 2012 at 15:42
''ARE YOU A SALESMAN for Code Sourcery ?''
Just for the record, no - I'm not.
Why do you find it an insult when someone simply points out to you that support options are available?
