Integration of real time data.
Mohan1
I am trying to estimate soc by coulomb counting method.In coulomb counting we required integration of discharge current.I am getting accurate discharge current but unable to add them by using array. I tried using array :
float buffer[50];
float current[50];
int i;
int k;
buffer[0]=0;
buffer[i]=buffer[i]+current[k]*1.1;   //Addition of current.
Please give me any suggestion.
Thanks.
This again? https://community.st.com/s/question/0D50X0000BvkAQjSQM/how-can-we-integrate-continuous-datareal-time-data
You really should get with your teachers/professors and get some clear instruction on C programming and arrays. Challenge them to do a better job.
I'm not a fan of paint-by-numbers, or rote learning methods, they lack any critical thinking and creativity.
There is a real need to understand the underlying programming methods here. If the method I outlined before can't be translated into C, you need to go back to the C / logic side of your knowledge, and fix or fill that out. Lacking effective instruction by your teachers, I'd suggest K&R's book on the C language as a good foundation.
Mohan1
@Community member​ sorry sir,i posted it bymistakely.
