2021-12-20 03:55 AM
2021-12-21 06:16 AM
Should be straightforward to do a bandwidth calculation.
460800 baud at 10 bits per byte (8 data bits, 0 parity, 1 start bit, 1 stop bits) means you can push 46080 bytes/sec. 32000 bytes/sec is less than that, so it can work.
