IAR Linking problem
‎2013-06-19 11:08 AM
hello
i have a folder contains many projects and all of them goes to same library file , each projects work great , but when i copy the main code of one project to other i got the linking problem like that ''Error[Li005]: no definition for....''- Mark as New
‎2013-06-20 4:32 AM
Error[Li005]: no definition for ''RCC_APB2PeriphClockCmd'' [referenced from C:\Users\Wissem\Desktop\my work\Debug\Obj\main.o]
Error[Li005]: no definition for ''GPIO_Init'' [referenced from C:\Users\Wissem\Desktop\my work\Debug\Obj\main.o] Error[Li005]: no definition for ''SYSCFG_EXTILineConfig'' [referenced from C:\Users\Wissem\Desktop\my work\Debug\Obj\main.o] Error[Li005]: no definition for ''EXTI_Init'' [referenced from C:\Users\Wissem\Desktop\my work\Debug\Obj\main.o] Error[Li005]: no definition for ''NVIC_Init'' [referenced from C:\Users\Wissem\Desktop\my work\Debug\Obj\main.o]- Mark as New
‎2013-06-20 4:53 AM
Does the ''offending'' source file include a device-specific header like stm32fxxx.h ?
(''#include ''stm32f4xx.h'' in the case of STM32F4). Do you have the define ''USE_STDPERIPH_DRIVER'' added to your project settings ? Take closer look at a working example project, and try to understand how this StdPeriph_Lib headers are working.- Mark as New
‎2013-06-20 6:40 AM
everything is okay , even i got two projects from ST site and they work great , but when i copy one source code to the other project this error comes up , all the libraries are in the right path just it says ''no definition...'' so it seems like the compiler read the fonction but it didnt find its source code
‎2013-06-20 7:28 AM
Did you check what I recommended - probably not ? Do you have the define ''USE_STDPERIPH_DRIVER'' added to your project settings ? Find the stm32f4xx.h file, open it in the editor, and search for the string '' USE_STDPERIPH_DRIVER''. If you look more closely, you will notice that stm32f4xx.h includes the stm32f4xx_conf.h file ONLY if this macro is defined. In my version at lines 7812 ff:
#ifdef USE_STDPERIPH_DRIVER
#include ''stm32f4xx_conf.h''
#endif /* USE_STDPERIPH_DRIVER */
The file
stm32f4xx_conf.h in turn includes the StdPeriph_Lib headers, where all those missing structs etc. are defined. Hence you need to define this macro globally (for the whole project). The best place are the project/build settings.
Of course you need to have such a file
stm32f4xx_conf.h in your project. If necessary, copy one over from another project, and adapt it.
Again:
‎2013-06-20 7:30 AM
And BTW, you need to add the required/used StdPeriph_Lib source files to your project, too.
‎2013-06-20 7:31 AM
‎2013-06-20 7:58 AM
trust me it works and i tried it on my board , but when i copy an another working project on the same workspace i got this errors
ps: every library is inculded and nothing is missing- Mark as New
‎2013-06-20 7:59 AM
the two projects have the prerocessus and includes paths
‎2013-06-20 8:25 AM
Copying the files is not enough, you have to clone the project and retain the meta-data (include paths, defines, optimization, settings, etc) associated with the project.Up vote any posts that you find helpful, it shows what's working..
