I2C Multiplexer
ugur
Posted on November 03, 2016 at 16:08
Hi I am triyng to use multiple MPU9250�s with Motion Driver 6.12 with STM32F4 Discovery. I am using TCA9548A 8 channel i2c multiplexer.
In arduino solution
Wire.beginTransmission(TCAADDR);
Wire.write(1 << i);
Wire.endTransmission();
code block is being used.
But I can not find the equivalent code in Motion Driver 6.12 in IAR Embedded Workbench.
Does anyone has experience about this.
Best regards,
#i2c-multiplexer
slimen
Posted on November 04, 2016 at 11:57
Maybe you should contact IAR support, they can help you on this topic.
