I want to use NUCLEO-H745ZI-Q to Connect SDRAM by FMC . But this Development Boards has 144 pins, it not has from FMC_A0 to FMC_A12 pins, and FMC BA0,BA1.So what should I do? Thanks
HDaba.1
Find a different board.
You're not going to want to wire it up with DuPont wires in any case.
Perhaps there is a breakout board, or one where you can remove and substitute an H745?
