I/O Mirroring
jeffrey2399
Posted on September 26, 2016 at 16:23
I need to simply capture an input level and then output the same logic level as soon as possible on another pin.
This can be simply done with EXTI, but I was wondering if there is a passive peripheral based solution that could be done without software intervention.
I was wondering if one of the TIMERs could be re-purposed this way or some other peripheral?
Posted on September 26, 2016 at 17:33
Here we tend to use wire to achieve such effects.
TIM units would tend to divide (ie /2)
DMA doesn't really have the read/write functionality desired, and doesn't support bit-banding.
EXTI could be done quite efficiently.
What latency exactly are you looking for?
Posted on September 24, 2017 at 08:42
LOL @ dry British humour...
