I'm using an STM32L412 and would like to start and stop a PWM output through software. Is it possible to use TIM16 and control the break function through software?
DamageG
KnarfB
The timer EGR register has a BG (break generation) bit for that. See reference manual.
Alternatively you migth use the MOE bit to set the output to idle state.
hth
KnarfB
DamageG
Thank you! I'll give it a try
