I have Enabled the SWV ITM Data Console and i am able to see the print out put . when I changed the optimization level to optimize for debug(-Og) or optimize for size (-Os) then i cant data see the SWV console! have revert level to None also not working
sshan.2
Amel NASRI
Hi @ss.7hankar​ ,
Some hints:
  • Is the issue common for any STM32 product you are using or specific for only one?
  • Does it depend on the application or appears with all projects?
  • Which IDE are you using?
You may find other hints in the STM32 Debug Toolset application note.
-Amel
