2025-04-14 1:11 AM
I am using 30 Mhz crystal oscillator, and when I configure clock for 30 Mhz it doesn't work properly but when I configure 16 Mhz it works properly.
2025-04-15 7:26 AM
@ChaitanyaParate wrote:
Yes it is the same project and i accepted it as solution.
I replaced R16 with 110 ohm resistor.
Ok but what was the result?
2025-04-25 4:11 AM
Please review this new article: How to select a compatible crystal and load capacitors for STM32 with layout guidelines
