How to use USB as Mass Storage Class ?
antonius
Posted on March 01, 2017 at 22:17
Everybody,
This question is related with SDIO I had done intiating,
Which configuration file do  I need to change ?
I can see drive E on my computer now, but can not read the content yet,
Anyone knows ?
13 REPLIES 13
Posted on March 02, 2017 at 23:10
This one ?
STM32Cube\Repository\STM32Cube_FW_F1_V1.4.0\Projects\STM3210E_EVAL\Applications\USB_Device\MSC_Standalone
usbd_storage.c, how to relate them ?
Posted on March 02, 2017 at 23:11
    • * @file USB_Device/MSC_Standalone/Src/usbd_storage.c**
    • * @author MCD Application Team**
    • * @version V1.4.0**
    • * @date 29-April-2016**
    • * @brief Memory management layer**
    • * @attention**
    • * h2. <center>© Copyright © 2016 STMicroelectronics
International N.V. **
    • * All rights reserved.</center>
    • * Redistribution and use in source and binary forms, with or without **
    • * modification, are permitted, provided that the following
conditions are met:**
    • * 1. Redistribution of source code must retain the above copyright
notice, **
    • * this list of conditions and the following disclaimer.**
    • * 2. Redistributions in binary form must reproduce the above
copyright notice,**
    • * this list of conditions and the following disclaimer in the
documentation**
    • * and/or other materials provided with the distribution.**
    • * 3. Neither the name of STMicroelectronics nor the names of other **
    • * contributors to this software may be used to endorse or promote
products **
    • * derived from this software without specific written permission.**
    • * 4. This software, including modifications and/or derivative works
of this **
    • * software, must execute solely and exclusively on
microcontroller or**
    • * microprocessor devices manufactured by or for STMicroelectronics.**
    • * 5. Redistribution and use of this software other than as permitted
under **
    • * this license is void and will automatically terminate your
rights under **
    • * this license. **
    • * THIS SOFTWARE IS PROVIDED BY STMICROELECTRONICS AND CONTRIBUTORS
'AS IS' **
    • * AND ANY EXPRESS, IMPLIED OR STATUTORY WARRANTIES, INCLUDING, BUT
NOT **
    • * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR
A **
    • * PARTICULAR PURPOSE AND NON-INFRINGEMENT OF THIRD PARTY
INTELLECTUAL PROPERTY**
    • * RIGHTS ARE DISCLAIMED TO THE FULLEST EXTENT PERMITTED BY LAW. IN
NO EVENT **
    • * SHALL STMICROELECTRONICS OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT,
INDIRECT,**
    • * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
(INCLUDING, BUT NOT**
    • * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
USE, DATA, **
    • * OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
THEORY OF **
    • * LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
(INCLUDING **
    • * NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
SOFTWARE,**
    • * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.**
*/ Includes
Posted on March 03, 2017 at 09:45
  • Function Name : STORAGE_Init_FS
  • Description :
  • Input : None.
  • Output : None.
  • Return : None.
int8_t STORAGE_Init_FS (uint8_t lun)
/* USER CODE BEGIN 2 */
printf('STORAGE_Init_FS function!\n');
  • BSP_SD_Init(); <=== Why is it stopped here ?? It's working without
USB.*
return (USBD_OK);
/* USER CODE END 2 */
  • Function Name : STORAGE_GetCapacity_FS
  • Description :
  • Input : None.
  • Output : None.
  • Return : None.
int8_t STORAGE_GetCapacity_FS (uint8_t lun, uint32_t *block_num,
uint16_t *block_size)
/* USER CODE BEGIN 3 */
HAL_SD_Get_CardInfo(&hsd, &SDCardInfo);
*block_num = SDCardInfo.CardCapacity / STORAGE_BLK_SIZ;
*block_size = STORAGE_BLK_SIZ;
printf('STORAGE_GetCapacity function!\n');
return (USBD_OK);
/* USER CODE END 3 */
Posted on March 03, 2017 at 11:39
MX_SDIO_SD_Init(); <== answer my question, now it's working like a charm
//BSP_SD_Init();
return (USBD_OK);
Still got unexpected error for reading message when I login ???
