How to use the STM32 Ecosystem Software
fernando maldonado
Posted on April 30, 2018 at 15:58
Hi Everyone!
   Greetings from Argentina!
   Please, Could you tell me how to use the STM32 Ecosystem Software, to create the necessary files for a Board Support Package to be able to develop in Keil uVision MDK.
   The most important file is the   RTE_Device.h   ,because the others are in the STMCubeMX ZIP file STM32H7xx -although the zip file has all the necessary environment for the STM32H743I-Eval
Thank you very much for your warmth, empathy and genuine answer.
Imen.D
Posted on May 02, 2018 at 12:20
Hello
old.aleph
http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-mcu-packages/stm32cubeh7.html
firwmare package
provides a rich set of examples and applications. They comewith the pre-configured projects for Keil toolchain. You may start from the template project in the STM32CubeH7 package and then add your own modifications (new functions, new files)...Please, have a look to thisUM2204 User manual Getting started with STM32CubeH7 for STM32H7 Series.
I recommend you to download the
http://www.st.com/en/development-tools/stm32cubemx.html?sc=stm32cubemx
which is a graphical software configuration tool that allows generating C initialization code using graphical wizards.For getting started STM32CubeMX, take a look to
http://www.st.com/content/ccc/resource/technical/document/user_manual/10/c5/1a/43/3a/70/43/7d/DM001047pdf/files/DM001047pdf/jcr:content/translations/en.DM001047pdf
Hope this helps you.
Best Regards
Imen
Imen
Posted on May 02, 2018 at 16:29
Keil/ARM, or partners, probably have training for RTE/MDK related topics.
ST maintains a list of consultants/contractors for engineering support tasks.
You should review the BSP code available for the EVAL board, and how you can migrate/port that to specific tools and run-time environments.
STM32Cube_FW_H7_V1.2.0\Drivers\BSP\STM32H743I_EVAL\STM32H743I_EVAL_BSP_User_Manual.chm
