2018-04-30 6:58 AM
Hi Everyone!
Greetings from Argentina!
Please, Could you tell me how to use the STM32 Ecosystem Software, to create the necessary files for a Board Support Package to be able to develop in Keil uVision MDK.
The most important file is the RTE_Device.h ,because the others are in the STMCubeMX ZIP file STM32H7xx -although the zip file has all the necessary environment for the STM32H743I-EvalThank you very much for your warmth, empathy and genuine answer.2018-05-02 3:20 AM
Hello
old.aleph
,firwmare package
provides a rich set of examples and applications. They comewith the pre-configured projects for Keil toolchain. You may start from the template project in the STM32CubeH7 package and then add your own modifications (new functions, new files)...Please, have a look to thisUM2204 User manual Getting started with STM32CubeH7 for STM32H7 Series.I recommend you to download the
http://www.st.com/en/development-tools/stm32cubemx.html?sc=stm32cubemx
which is a graphical software configuration tool that allows generating C initialization code using graphical wizards.For getting started STM32CubeMX, take a look to .Hope this helps you.
Best Regards
Imen
2018-05-02 7:29 AM
Keil/ARM, or partners, probably have training for RTE/MDK related topics.
ST maintains a list of consultants/contractors for engineering support tasks.
You should review the BSP code available for the EVAL board, and how you can migrate/port that to specific tools and run-time environments.
STM32Cube_FW_H7_V1.2.0\Drivers\BSP\STM32H743I_EVAL\STM32H743I_EVAL_BSP_User_Manual.chm
