How to set RDP level2 without a password with STM32_Programmer_CLI
acapola
I am using NUCLEO-u5a5zj-q, I tried this:
sru@sru-pqs-dell:~/repos/pqkey$ STM32_Programmer_CLI --connect port=swd index=2 -halt --optionbytes displ -ob nSWBOOT0=0 nBOOT0=1 -lockRDP2 0xFFFFFFFF 0xFFFFFFFF
                        STM32CubeProgrammer v2.16.0
ST-LINK SN  : 004900253532510831333430
ST-LINK FW  : V3J15M6
Board       : NUCLEO-U5A5ZJ-Q
Voltage     : 3,28V
SWD freq    : 8000 KHz
Connect mode: Normal
Reset mode  : Software reset
Device ID   : 0x481
Revision ID : Rev X
Device name : STM32U5xx
Flash size  : 4 MBytes (default)
Start Address : 8000000
Device type : MCU
Device CPU  : Cortex-M33
BL Version  : 0x92
Debug in Low Power mode enabled
Core halted
UPLOADING OPTION BYTES DATA ...
  Bank          : 0x00
  Address       : 0x40022040
[==================================================] 100%
  Bank          : 0x01
  Address       : 0x40022068
OPTION BYTES BANK: 0
   Read Out Protection:
     RDP          : 0xAA (Level 0, no protection)
   BOR Level:
     BOR_LEV      : 0x0 (BOR Level 0, reset level threshold is around 1.7 V)
   User Configuration:
     TZEN         : 0x0 (Global TrustZone security disabled)
     nRST_STOP    : 0x1 (No reset generated when entering Stop mode)
     nRST_STDBY   : 0x1 (No reset generated when entering Standby mode)
     nRST_SHDW    : 0x1 (No reset generated when entering the Shutdown mode)
     SRAM1345_RST : 0x1 (SRAM1, SRAM3,SRAM4 and SRAM5 not erased when a system reset occurs)
     IWDG_SW      : 0x1 (Software independent watchdog)
     IWDG_STOP    : 0x1 (IWDG counter active in stop mode)
     IWDG_STDBY   : 0x1 (IWDG counter active in standby mode)
     WWDG_SW      : 0x1 (Software window watchdog)
     SWAP_BANK    : 0x0 (Bank 1 and bank 2 address are not swapped)
     DBANK        : 0x1 (Dual-bank Flash with contiguous addresses)
     BKPRAM_ECC   : 0x1 (Backup RAM ECC check disabled)
     SRAM3_ECC    : 0x1 (SRAM3 ECC check disabled)
     SRAM2_ECC    : 0x1 (SRAM2 ECC check disabled)
     SRAM2_RST    : 0x1 (SRAM2 is not erased when a system reset occurs)
     nSWBOOT0     : 0x1 (BOOT0 taken from PH3/BOOT0 pin)
     nBOOT0       : 0x1 (nBOOT0 = 1)
     PA15_PUPEN   : 0x1 (USB power delivery dead-battery disabled/ TDI pull-up activated)
     IO_VDD_HSLV  : 0x0 (High-speed IO at low VDD voltage feature disabled (VDD can exceed 2.5 V))
     IO_VDDIO2_HSLV: 0x0 (High-speed IO at low VDDIO2 voltage feature disabled (VDDIO2 can exceed 2.5 V))
   Boot Configuration:
     NSBOOTADD0   : 0x100000  (0x8000000)
     NSBOOTADD1   : 0x17F200  (0xBF90000)
   Write Protection 1:
     WRP1A_PSTRT  : 0xFF  (0x81FE000)
     WRP1A_PEND   : 0x0  (0x8000000)
     UNLOCK_1A    : 0x1 (WRP1A start and end pages unlocked)
     WRP1B_PSTRT  : 0xFF  (0x81FE000)
     WRP1B_PEND   : 0x0  (0x8000000)
     UNLOCK_1B    : 0x1 (WRP1B start and end pages unlocked)
OPTION BYTES BANK: 1
   Write Protection 2:
     WRP2A_PSTRT  : 0xFF  (0x83FE000)
     WRP2A_PEND   : 0x0  (0x8200000)
     UNLOCK_2A    : 0x1 (WRP2A start and end pages unlocked)
     WRP2B_PSTRT  : 0xFF  (0x83FE000)
     WRP2B_PEND   : 0x0  (0x8200000)
     UNLOCK_2B    : 0x1 (WRP2B start and end pages unlocked)
PROGRAMMING OPTION BYTES AREA ...
Warning: Option Byte: nboot0, value: 0x1, was not modified.
  Bank          : 0x00
Reconnecting...
Reconnected !
  Bank          : 0x00
  Bank          : 0x01
OPTION BYTE PROGRAMMING VERIFICATION:
Option Bytes successfully programmed
Time elapsed during option Bytes configuration: 00:00:02.127
Lock RDP2 password successfully done
sru@sru-pqs-dell:~/repos/pqkey$ ./status-stm32u5a5 2
+ index=2
+ name=2
+ addr=0x08000000
+ STM32_Programmer_CLI --connect port=swd index=2 -halt --power off index=2 --power on index=2
Voltage     : 3,28V
SWD freq    : 8000 KHz
Device ID   : 0x481
Revision ID : Rev X
Device type : MCU
BL Version  : 0x92
Core halted
Power OFF...
Drives the target power pin out of the (onboard) ST-Link.
Info: Power ON/OFF maybe not available on your Board [also not available on standalone probes]
Power OFF the board finished with success !
Power ON...
Power ON the board finished with success !
+ STM32_Programmer_CLI --connect port=swd index=2 -halt --optionbytes displ --blankcheck
Voltage     : 3,28V
SWD freq    : 8000 KHz
Device ID   : 0x481
Revision ID : Rev X
Device type : MCU
BL Version  : 0x92
Core halted
  Bank          : 0x00
  Bank          : 0x01
   BOR Level:
   User Configuration:
     nSWBOOT0     : 0x0 (BOOT0 taken from the option bit nBOOT0)
   Boot Configuration:
   Write Protection 1:
   Write Protection 2:
Flash memory blank checking...
Time elapsed during the blank check operation is: 00:00:00.015
Warning: Flash memory is not empty at 0x08000000.
As you can see, the RDP level is still 0 (and later on I could still dump all memories).
On the same board I have been able to set RDP level 2 without password using the GUI version (STM32CubeProgrammer), so the setup was right.
Diane POMABIA
Hello @acapola
To be clear, if you go to RDP level 2 without setting a password beforehand, you won't be able to go back.
Here is  examples of a command, you can configure the right path for your PC.
Without Password
@ECHO OFF
SETLOCAL
SET TOOLDIR=c:\Program Files\STMicroelectronics\STM32Cube\CubeProgrammer1.14\bin
SET TOOL=%TOOLDIR%\STM32_Programmer_CLI.exe
SET MY_CURR_DIR=%cd%
@ECHO ON
cd %TOOLDIR%
"%TOOL%" -c port=SWD mode=HOTPLUG  -ob displ
"%TOOL%" -c port=SWD mode=HOTPLUG  -ob RDP=0xCC
cd %MY_CURR_DIR%
@ENDLOCAL
@PAUSE
With password:
@ECHO OFF
SETLOCAL
@ECHO ON
cd %TOOLDIR%
"%TOOL%" -c port=SWD mode=HOTPLUG  -lockRDP2 0x12345678 0xABCDEFAB
"%TOOL%" -c port=SWD mode=HOTPLUG  -unlockRDP2 0x12345678 0xABCDEFAB
"%TOOL%" -c port=SWD mode=HOTPLUG  -ob RDP=0xAA
cd %MY_CURR_DIR%
@ENDLOCAL
@PAUSE
DianeP
Diane POMABIA
Hello @acapola
Without Password
@ECHO OFF
SETLOCAL
@ECHO ON
cd %TOOLDIR%
cd %MY_CURR_DIR%
@ENDLOCAL
@PAUSE
With password:
@ECHO OFF
SETLOCAL
@ECHO ON
cd %TOOLDIR%
cd %MY_CURR_DIR%
@ENDLOCAL
@PAUSE
DianeP
Note that without password, the second attempt to display option bytes is failing and it is expected since we have locked the JTAG.
