How to protect FW from copying on not original boards
MartinL
Hello ST,
We are developing device and we want to provide free FW updates if some bugs occurre.
Updates will be flashed via DFU - usb communication.
Currently we are using STM32F411CEU6.
Can you recommend best options for protecting the FW from being copied to a non-original board? Is it possible? Or the only option will be to use your new MCUs with firmware encryption feature? Can you suggest pin-pin replacement for F411?
Thank you
Best regards,
Martin
0 REPLIES 0
