How to program to external flash on custom board
Minh Phan
Posted on December 29, 2017 at 02:17
Hi everybody!
I have problem with download hex file to memory.
My project uses STM32F769 and QSPI (MX25L51245G).
Here is pin map of QSPI:
QSPI_NCS <-----------------> PB6
QSPI_CLK <-----------------> PB2
QSPI_D0 <-----------------> PD11
QSPI_D1 <-----------------> PC10
QSPI_D2 <-----------------> PE2
QSPI_D2 <-----------------> PD13
This pin map of QSPI is different with pin map of QSPI on STM32F769 Discovery board.
When I use the ST Demo hex file to program to my custom board by ST link Utility, it shows message: ''time out during flash program''.
Here is image:
Could you please help me to solve this ?
Thank you very much.
#qspi-flash #custom-board #stm32f769i
Peter Chang
Posted on March 05, 2018 at 05:30
It looks like no way to change ST-LINK pin configuration to QSPI Flash.
I suggest use external programmer to program your code.
http://www.hilosystems.com.tw/en/programmers/all-200#specification
Rohit  Mishra
Posted on March 13, 2018 at 10:46
Hi Minh Phan,
how did you solve your problem .........?
We too have made a custom board for stm32f7, and are facing the same issue.
The nor flash is not getting programmed using st-link.
If you have solved your problem, please let us know the solution.
Thanks and Best Regards,
rohit mishra.
Posted on March 13, 2018 at 14:03
You would need to craft a custom external loader to address the specifics of your board and part choices.
