How to map PA2 to Nucleo CN10:37?
I'm unable to successfully see my PWM signal on the Nucleo STM32F302R8 development board, connector 10, pin 37.
I have SB62 and SB59 connected with 0-ohm resistors. I don't understand why the same pin is on multiple pins. Absolute pin number 17 AND 18.
https://www.st.com/en/evaluation-tools/nucleo-f302r8.html
https://www.st.com/resource/en/schematic_pack/nucleo_64pins_sch.zip
Which solder bridges should I short?
