Step by step guide on building lora subghz project in cube ide
Greetings,
I have tried lora on STM32 nucleo bards. I want to learn to make custom code for STM-32-WL-E5CCU using cube mx. Is it possible ? I want to implement LORA SubGHz and not LORA WAN. Is there any tutorial pdf or video that teaches or gives some insight for building applications for lora using cube mx ?
STTwo-32
Hello @Nimit Vachhani
I suggest you follow this tutorial video. together with the examples available here and this example. You should be able to understand how it works and implemented on your own.
Best Regards.
STTwo-32
