How to look at floating-point number calculation result with EWARM
Ken Inoue
Posted on November 09, 2017 at 10:11
Thank you for your patronage. I'm using STM32F3348-Discoverywhich has FPU and EWARM.
I made calculations like the picture below.
I'd like to check if floating point arithmetic is calculated correctly. So,I added z to EWARM live watch. Butz indicated an error.In case of integer operation, it is correctly displayed.How can I do it?
Best Regards,
Ken Inoue
Andrew Neil
Evangelist III
Posted on November 09, 2017 at 10:39
Having paid the considerable licence fee for EWARM, don't you think you should be asking them about difficulties with their product ... ?!
https://www.iar.com/support/technical-support/
But, anyhow, what is the text following 'Error(...' in your screenshot?
General points - not specific to IAR:
  • Is z in-scope at the point you are trying to observe it?
  • Is the value of z ever used for anything non-trivial?
    If not, the compiler may well have optimised it away...
4 REPLIES 4
Andrew Neil
Evangelist III
174712CGIL2
Posted on November 09, 2017 at 12:10
Do you understand the concept of scope in the 'C' programming language?
A variable is not visible outside its scope - not even to a debugger ...
Posted on November 09, 2017 at 12:37
I will study that.
Thanks.
Best Regards,
Ken Inoue
