how to force complementary outputs ?
mehmet.karakaya
Posted on November 20, 2010 at 14:14
mehmet.karakaya
Posted on May 17, 2011 at 14:15
nobody has any idea ?
a second reason for not using GPIO for low side switches
is BKIN input to be functional
lowpowermcu
Hi Mehmet,
If you are using ST library you should use this config:
  TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Disable;
To disable break functionality use:
TIM_BDTRInitStruct->TIM_Break = TIM_Break_Disable;
Tell if you are using register access level (perhaps I can help you)
MCU Lüfter
