how to establish ethernet connection in stm3210c eval board , what settings to be done to do that, pls help me urgently required
charu singh
Posted on July 27, 2017 at 07:33
i have purchased a stm3210c Eval board , want to establish ethernet connection  but unable to do it
pls tell me the solution , and suggest how to transmit data from microcontroller to PC via ethernet
Imen.D
Posted on August 01, 2017 at 16:24
Hello
singh.charu
As said by
FORTOUNAS.EVANGELOS
, you can review Ethernet examples as you can find available in the STM32CubeF1 package dedicated for the
STM3210C_EVAL
board: STM32Cube_FW_F1_V1.6.0\Projects\STM3210C_EVAL\Applications\LwIP
Have a look to this manual UM1709, it maybe helpfuland
http://www.st.com/content/ccc/resource/technical/document/user_manual/65/e8/20/db/16/36/45/f7/DM001036pdf/files/DM001036pdf/jcr:content/translations/en.DM001036pdf
is a user manual about “Developing applications on STM32Cube with LwIP TCP/IP stack�? which can help you a lot to go further in your application.
Imen
Imen
