2023-12-22 02:08 AM
Hi guys,
I am read the example "STM32Cube_FW_F1_V1.8.4\Projects\STM32F103RB-Nucleo\Examples\FLASH\FLASH_WriteProtection", and want to rewrite it on my board.
my code is as follows:
HAL_FLASH_Unlock();
HAL_FLASH_OB_Unlock();
HAL_FLASHEx_OBGetConfig(&OptionsBytesStruct);
LOG_DBG("current config: WRPState[%d]\n", OptionsBytesStruct.WRPState);
LOG_DBG("current config: WRPPage[0x%08x]\n", OptionsBytesStruct.WRPPage);
if((OptionsBytesStruct.WRPPage & FLASH_PAGE_TO_BE_PROTECTED) == FLASH_PAGE_TO_BE_PROTECTED) { // if WRP enable
LOG_DBG("Flash is WriteProtection\n");
OptionsBytesStruct.OptionType = OPTIONBYTE_WRP;
OptionsBytesStruct.WRPState = OB_WRPSTATE_DISABLE;
OptionsBytesStruct.WRPPage = FLASH_PAGE_TO_BE_PROTECTED;
if(HAL_FLASHEx_OBProgram(&OptionsBytesStruct) != HAL_OK) {
LOG_ERR("Flash OB program err when turn WRP off\n");
HAL_Delay(10000);
LOG_DBG("system reset\n");
HAL_Delay(1000);
HAL_FLASH_OB_Launch();
} else {
LOG_DBG("Flash is NOT WriteProtection\n");
OptionsBytesStruct.WRPState = OB_WRPSTATE_ENABLE;
LOG_ERR("Flash OB program err when turn WRP on\n");
HAL_Delay(10000);
HAL_Delay(1000);
HAL_FLASH_OB_Lock();
HAL_FLASH_Lock();
The output is as this:
Flash Write Protection demo...
current config: WRPState[0]
current config: WRPPage[0xFFFFFFFF]
system reset
system reset
system reset
What I expected of the output should be like "WRP_EN --> WRP_DIS -->WRP_EN --> WRP_DIS ......".
I have no idea what I was wrong, help me, please.
Thank you.
BTW, I am confused about the result of "HAL_FLASHEx_OBGetConfig(&OBStruct);", if the result as below:
LOG_DBG("current config: WRPState[%d]\n", OptionsBytesStruct.WRPState); // 0
LOG_DBG("current config: WRPPage[0x%08x]\n", OptionsBytesStruct.WRPPage); // 0xFFFFFFFF
Then, does that mean all the flash is WRP, or all the flash is NOT in WRP?
Thanks again for your help in advance.
2023-12-22 02:59 AM
Hello @Junde
Referring to PM0068, you can check write protection definition (0 for activated WRP).
2023-12-22 02:59 AM
Hello @Junde
2023-12-24 06:53 PM
@FBL Thanks for your help.
I was wrong about the meaning of the FLASH_WRPR bit.(0 is for active, NOT 1)
So my code should be as this:
HAL_FLASH_Unlock();
if((~OptionsBytesStruct.WRPPage & FLASH_PAGE_TO_BE_PROTECTED) == FLASH_PAGE_TO_BE_PROTECTED) { // if WRP enable
HAL_Delay(10000);
HAL_Delay(1000);
} else {
HAL_Delay(10000);
HAL_Delay(1000);
HAL_FLASH_Lock();
2024-10-17 06:45 PM - edited 2024-10-17 06:46 PM
Checking WRPState is useless, because this field is never set in HAL_FLASHEx_OBGetConfig() function:
void HAL_FLASHEx_OBGetConfig(FLASH_OBProgramInitTypeDef *pOBInit)
pOBInit->OptionType = OPTIONBYTE_WRP | OPTIONBYTE_RDP | OPTIONBYTE_USER;
/*Get WRP*/
pOBInit->WRPPage = FLASH_OB_GetWRP();
/*Get RDP Level*/
pOBInit->RDPLevel = FLASH_OB_GetRDP();
/*Get USER*/
pOBInit->USERConfig = FLASH_OB_GetUser();
/* WRPState was never set! */
You can only rely on WRPPage, RDPLevel and USERConfig fields.
WRPState is only useful when you set OBInit.WRPState to OB_WRPSTATE_EBABLE or OB_WRPSTATE_DISABLE and then feed OBInit to the HAL_FLASHEx_OBProgram().
