How to corretly stop timer
Posted on February 13, 2015 at 21:41
Hello, I am measuring voltage via ADC, using timer TRGO interrupt trgiggered DMA. After measuring 1000samples I need to stop, proces meassured data and then continue in meassuring. I stop timer by:
TIM_ITConfig(TIM3, TIM_IT_Update, DISABLE);and after data processing I run timer again by:TIM_ITConfig(TIM3, TIM_IT_Update, ENABLE);
But in debug after TIM_ITConfig(...., DISABLE); new samples are still coming and overwriting old samples. How is it possible when I stopped timer update? When I use: TIM_Cmd(TIM3, DISABLE); everything is OK, but I dont know if it is neccesary to turn off whole timer.... Thank you for answeres and ideas.
