GS1
Senior III
December 29, 2020
How to correctly set up FDCAN Message RAM Start Addresses?
  • December 29, 2020
  • 1 reply
  • 4375 views
How do I have to set the configuration of the FDCAN Message RAM Start Adresses correctly in order to use 2 CANFDs simultaneously?
Is there an example which shows a correct initialisation? The default samples initialize all start Adresses to 0, but this leads to Message corruption!
Here my sample code:
Would this be correct?
   if (nCan == CAN0)
      phCan->Instance = FDCAN1;
      uCANOffset = 0;
   else
      phCan->Instance = FDCAN2;
      uCANOffset = 1024;
   phCan->msgRam.StandardFilterSA = 0;
   phCan->msgRam.ExtendedFilterSA = 0;
   // Start-Adressen für Message-RAM:
   phCan->msgRam.RxFIFO0SA = 0+uCANOffset;
   phCan->msgRam.RxFIFO1SA = 512+ uCANOffset;
   phCan->msgRam.RxBufferSA = 1024;
   phCan->msgRam.TxEventFIFOSA = 0;
   phCan->msgRam.TxBufferSA = 0;
   phCan->msgRam.TxFIFOQSA = 0;
   phCan->msgRam.TTMemorySA = 0;
   phCan->msgRam.EndAddress =0;
   phCan->ErrorCode = 0;
Thank you for any help.
Best answer by GS1
OK, I got it:
The correct RAM initialisation is done as follows:
if (nCan == CAN0)
      uCANOffset = 0;
else
      uCANOffset = 1024;
   phCan->Init.MessageRAMOffset = uCANOffset;
   phCan->msgRam.RxFIFO0SA = 0;
   phCan->msgRam.RxFIFO1SA = 0;
   phCan->msgRam.RxBufferSA = 0;
   phCan->msgRam.EndAddress = 0;
This ensures that both CANs can be used without conflict in the RAM for receiving messages.
Hope this helps others for initialising 2 x FDCAN-Bus ports.
Now this is a good start into 2021 for me !!!
1 reply
GS1
GS1AuthorBest answer
Senior III
December 30, 2020
OK, I got it:
if (nCan == CAN0)
      uCANOffset = 0;
else
      uCANOffset = 1024;
