How to Convert UART received data into Float
‎2023-09-02 12:13 AM
HI
"I am using an STM32G071CBT6 controller, and I am receiving data using the receive interrupt. I have received some values in my buffer memory, and now I want to convert them to float. If you have any examples, please share them. My buffer memory is of type uint8_t rx_data[1]
STM32G0 Series
‎2023-09-02 6:29 AM
Would suggest polishing your C skills, perhaps easier on a PC than embedded. Currently you'd fail at interview.
#define STRBUFLEN 32
void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart)
static int index = 0;
static char string[STRBUFLEN + 1];
char c;
/* Prevent unused argument(s) compilation warning */
UNUSED(huart);
/* NOTE : This function should not be modified, when the callback is needed,
the HAL_UART_RxCpltCallback can be implemented in the user file.
c = rxbuf[0]; // The byte received, first index
HAL_UART_Receive_IT(&huart3, rxbuf, sizeof(rxbuf)); // restart
HAL_UART_Transmit(&huart3, &c, sizeof(c), 10); // send the holding buffer, not active input one
if ((c == '\r') || (c == '\n') || (index >= STRBUFLEN)) // line termination
string[index] = 0; // NUL terminate string so usable by functions
if (index) // non-zero, ie has content
datar7 = atof(string);
index = 0; // reset pointer in buffer
else if (index < STRBUFLEN)
string[index++] = c;
‎2023-09-02 12:30 AM
Hello @suriya
You can do this:
float f;
f = (float)rx_data[1];
Hope this is helpful for you. If your question is answered please check this answer as best answer to be diffused.
Best regards.
II
‎2023-09-02 3:58 AM
Use sscanf() or atof() or atod()
‎2023-09-02 5:26 AM
Hi
I tried this, but it's not working. When I enter "3" in my serial monitor, I get "10.0". In fact, no matter what number I type, I always get "10", and nothing changes.
‎2023-09-02 5:29 AM
Hi
i tried atof() still not working.
‎2023-09-02 5:39 AM
‎2023-09-02 5:40 AM
‎2023-09-02 6:08 AM
rxbuf[1] is a char, the second in the array, The basis for the index is zero
The functions use strings, ie collections of bytes. You aren't going to hold a floating point string in a single byte.
Strings need to be NUL terminated.
You need to accumulate a string from the bytes as you receive them, and when you've got enough THEN do the conversion on the string.
‎2023-09-02 6:29 AM
char c;
UNUSED(huart);
‎2023-09-02 3:06 PM
What values are you sending to the UART?
TimerCallback tutorial! | UART and DMA Idle tutorial!
