STM32F401RE
CCV
AREA mycode, CODE
  EXPORT __main
myclock EQU 0x40023830
myDmode EQU 0x40020000
myDout EQU 0x40020014
myPU_PD EQU 0x4002080C
myPC13I EQU 0x40020810
  ENTRY
__main PROC
  NOP
;------------------------------Port C Clock Enable
  LDR R1,=myclock
  LDR R5,[R1]
  MOV R2,#1
  LSL R2,#2
  ORR R5,R2
  STR R5,[R1]
;------------------------------PC13 Pull-Up Pull-Down
  LDR R1,=myPU_PD
  LDR R5,[R1]
  MOV R2,#1
  LSL R2,#26
  ORR R5,R2
  STR R5,[R1]
;---------------------------Clock uygulama PA5 LED, PC13 User Button
  LDR R1,=myclock
  LDR R5,[R1]
  MOV R2,#1
  LSL R2,#0
  ORR R5,R2
  STR R5,[R1]
;----------------------------Çikis uclari seçimi PA5
  LDR R1,=myDmode
  LDR R5,[R1]
  MOV R2,#0x1
  LSL R2,#10
  ORR R5,R2
  STR R5,[R1]
;------------------------------Read PC13 pin
Re_PC13 LDR R1,=myPC13I
     LDR R5,[R1]
  MOV R2,#0x2000
  AND R5,R2
  CMP R5,#0
  BEQ myRun
  B Re_PC13
;----------------------------Led On
myRun NOP
One2 LDR R1,=myDout
  LDR R5,[R1]
  ;MOV R2,#0xF
  MOV R2,#0x1
  ;LSL R2,#12
  LSL R2,#5
  ORR R5,R2
  STR R5,[R1]
;---------------------------- Gecikme
  LDR R6,=0XFFFFF
Two1 SUB R6,#1
  CMP R6,#0
  BEQ One1
  B Two1
;---------------------------- LED off
One1 LDR R1,=myDout
  LDR R5,[R1]
  LDR R2,=0xFFFFFFCF
  AND R5,R2
  STR R5,[R1]
  LDR R6,=0XFFFFF
Two2 SUB R6,#1
  CMP R6,#0
  BEQ Re_PC13
  B Two2
  ENDP
  END
I have a STM32F401RE . I have PA4 pin Input and PC7 pin Output. I need help. I need PA4 offset and PC7 offset. Can you rewrite the program using the new inputs and outputs?
Issamos
Lead III
Hello @CCV
This is a modified version of your code:
AREA mycode, CODE
EXPORT __main
myPC4I EQU 0x40020810 ; PA4 as Input
myPC7O EQU 0x40020C14 ; PC7 as Output
ENTRY
__main PROC
  NOP
  LDR R1,=myclock
  LDR R5,[R1]
  MOV R2,#1
  LSL R2,#2
  ORR R5,R2
  STR R5,[R1]
;------------------------------PC4 Pull-Up Pull-Down
  LDR R1,=myPU_PD
  LDR R5,[R1]
  MOV R2,#1
  LSL R2,#4
  ORR R5,R2
  STR R5,[R1]
;---------------------------Clock uygulama PA5 LED, PC7 Output
  LDR R1,=myclock
  LDR R5,[R1]
  MOV R2,#1
  LSL R2,#0
  ORR R5,R2
  STR R5,[R1]
;----------------------------Çikis uclari seçimi PC7 (0100)
  LDR R1,=myDmode
  LDR R5,[R1]
  MOV R2,#0x4
  LSL R2,#28
  ORR R5,R2
  STR R5,[R1]
;------------------------------Read PA4 pin
Re_PA4 LDR R1,=myPC4I
     LDR R5,[R1]
  MOV R2,#0x10
  AND R5,R2
  CMP R5,#0
  BEQ myRun
  B Re_PA4
;----------------------------Led On (PC7 High)
myRun LDR R1,=myDout
  LDR R5,[R1]
  MOV R2,#0x80
  ORR R5,R2
  STR R5,[R1]
  LDR R6,=0XFFFFF
Two1 SUB R6,#1
  CMP R6,#0
  BEQ One1
  B Two1
;---------------------------- LED off (PC7 Low)
One1 LDR R1,=myDout
  LDR R5,[R1]
  MOV R2,#0xFFFFFF7F
  AND R5,R2
  STR R5,[R1]
  LDR R6,=0XFFFFF
Two2 SUB R6,#1
  CMP R6,#0
  BEQ Re_PA4
  B Two2
  ENDP
  END
  Hope this is helpful. If your question is answered please check this answer as best answer to be diffused.
Best regards.
II
Sorry its doesnt work
Hello again
Then, you can open an exemple of code in C that do the same thing and then open the Disassembly View which is well described in this post. This view will give a transaction of the C code to assembly language. Then you can copie the assembly code and use it in your project .
Best regards.
II
