how the image is sent to the camera to the computer?
yesil_kaya76
Posted on August 12, 2013 at 10:32
I have a project with OV7670 with stm32f4-discovery. My OV7670 has 16 pins and without fifo.
I
'm having
a picture of
the camera and than
I have to send
my picture
to the computer. But
I have no idea
how
I'm gonna do
. Can anyone give me some direction how can I do? Thanks a lot.
18 REPLIES 18
yesil_kaya76
Posted on September 26, 2013 at 15:28
thanks alot fm for your suggestion. I found a new way for VGA format. I captured two pictures from camera without FIFO. After i combined this pictures as follow.
But, there are a problem. i dont removed black line in the middle of the Picture.
Black end White is a good idea. But as far as I know, camera does not support grayscale.
it supports just; YUV, RGB and RAW.
frankmeyer9
Posted on September 26, 2013 at 16:50
From my (rather feeble) knowledge of your project/code, it could well be a bug in how you 'stitch' the parts of the image together.
You can do a ''BW_Intensity = (Red + Green + Blue) / 3'' for each pixel on the fly, before storing it to the RAM buffer. As dave suggested, that would reduce your RAM footprint significantly - if you can live with BW pictures.
yesil_kaya76
Posted on September 30, 2013 at 17:13
Thanks a lot fm for everythings.
 My black line problem in the middle of the Picture is solved with your suggestion.
Now, only there is a problem. there are a lot
pink
blot in the my picture. How can I solve this problem.
Posted on September 30, 2013 at 17:45
The green stuff at the edge suggests you don't have the framing/timing right. Front/Back porch?
The pink stuff is more indicative that the colour bit assignments are wrong or misaligned bit stream. ie an issue extracting/decoding the RGB or YUV
Is the picture from a milling machine? Cut metal path?
yesil_kaya76
Posted on October 01, 2013 at 12:52
I solved the green stuff at the edge.
there are not pink stuff at the Picture when Picture was QVGA (320*240).
But, there are pink stuff at the Picture when Picture was VGA (640*480).
As follow :
yesil_kaya76
Posted on October 01, 2013 at 14:02
The original post was too long to process during our migration. Please click on the provided URL to read the original post. https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I6XH&d=%2Fa%2F0X0000000bq9%2F9OgIoCfbWynDYwV5fsjPCqZ0nkEQbvs2HW7MYDF8i.I&asPdf=false
pinnchus
Posted on October 09, 2013 at 15:01
Dear yesilkaya.seccad,
Would you
mind sharing
the complete code
Thanks,
Pinnchus
yesil_kaya76
Posted on October 22, 2013 at 08:58
yes i can share. you can contact to me with my mail adress :
mailto:yesil_kaya76@hotmail.com
pinnchus
Posted on October 22, 2013 at 14:32
I sent
an email
with my details.
Regards,
Pinnchus
